"The new program interface does not match the previously defined program interface" when commissioning an AS with an Externally Managed LonWorks Network configured
  • "The new program interface does not match the previously defined program interface" when commissioning an AS with an External...
  • Benji
    Benji
‎2018-09-06 08:46 AM
After upgrading, the AS is offline in LonMaker. An attempt to commission the AS results in an error shown: "The new program interface does not match the previously defined program interface".
  • Automation Server
  • Externally Managed LonWorks Network
  • LonMaker
There has previously been issues with the structure of the XIF created by the AS. This is corrected in newer versions, but as a result the XIF previously loaded in LonMaker will be different from the actual content in the AS.
Replace the AS in LonMaker uploading the XIF file again from the AS.
  • 18041
