"Select CASE" function will not check in a Plain English program.
  • "Select CASE" function will not check in a Plain English program.
  • PaulFr
    PaulFr
‎2018-09-06 12:28 PM
Can not save a PE Program in Continuum controller.
Cyberstation and CX controllers
BasedOn and Case statements
Not all keywords and functions are supported in all controllers.
When using keywords and inbuilt Plain English functions always verify it is supported by the controller you are using.
The "Select CASE" statement is only supported by the Cyberstation programs, if programming a controller use the BASEDON function that has a similar format and is supported by all controllers.
  • 7693
