"Register As Reader Expander" incremented by 1 when imported by Data Sync Service
  • "Register As Reader Expander" incremented by 1 when imported by Data Sync Service
  • PeterEdvik
    PeterEdvik
  • Mahmoud_Sayed
    Mahmoud_Sayed
Kirk Mahmoud_Sayed Kirk
‎2021-09-24 02:36 AM
on ‎2021-09-24 02:36 AM
When importing Security Expert controllers into Security Expert Server using the Data Sync Service, the Register As Reader Expander address field is different from the value in the CSV file. The address field is incremented by 1.
EcoStruxure Security Expert
  • Security Expert Server
  • Security Expert Data Sync Service
Register As Reader Expander values in the Security Expert SQL database are stored as integers where indexing starts at 0, whereas in the Security Expert Client the same values are displayed as integers starting at 1. The Data Sync Service updates the database values directly, which is why the values differ between the CSV file and the user interface.
In the CSV import file, decrement values in the Register As Reader Expander column by 1. For example: If the address in the user interface is '1', the value in the CSV file should be changed to '0'. See screenshot from Data Sync Service (left) and Security Expert Client (right) below.
  • EcoStruxure Security Expert
  • MahmoudSayed21
