"No Reply" when Purging Alarms
  • "No Reply" when Purging Alarms
  • sesa145087_brid
    sesa145087_brid
‎2018-09-06 12:54 PM
When purging alarm in AMT, and the I/O server is configured as serial port communication, there will be "No Reply" window popping up and Retry is useless.
I/NET
This may be caused the network communication issue. Or it may be due to other issues.
Disconnect the Server from network or disable the serial port in I/O configuration. After the alarms are purged, return to the original setting.
  • TAC INET
  • 6913
