"Maximum IOU/Infinet controllers reached" when adding an IOU module or Infinet controller.
  • "Maximum IOU/Infinet controllers reached" when adding an IOU module or Infinet controller.
  • ScottLeedberg
    ScottLeedberg
‎2018-09-06 03:02 PM
  • IOU module
  • Infinet controller
This generally means exactly what the message states. You have a node limited controller and you have reached the maximum number of nodes.
  1. Edit the controller through Continuum Explorer
  2. Click on the options tab.
  3. Verify the node counts on the controller on the options tab.
  4. If you have reached the maximum number of nodes contact the repair department to get a node upgrade flash file. There is a cost associated with this option.
  • 2337
