"Invalid status code: 401 Access Denied" on "Save Runtime DB" of the localhost
  • "Invalid status code: 401 Access Denied" on "Save Runtime DB" of the localhost
  • sesa116873_brid
    sesa116873_brid
‎2018-09-06 09:06 AM
Getting an "Invalid status code: 401 Access Denied" error when doing a "Save Runtime DB" of the localhost or a "Get" to save a remote UNC station to the localhost.
The errors read:
Error when doing a “Save Runtime DB” of localhost station:
tridium.nre.net.HttpException: Invalid status code: 401 (Access denied)
           at tridium.ui.admintool.DbAdminConfigPanel.doRemoteBackup(DbAdminConfigPanel.java:1100)
           at tridium.ui.admintool.DbAdminConfigPanel$Worker.run(DbAdminConfigPanel.java:1224)
Error when doing a “Get” of a remote UNC station:
           java.io.FileNotFoundException: c:\niagara\r2.301.535\stations\anystation\config.sns (Access is denied)
           at java.io.FileOutputStream.open(Native Method)
           at java.io.FileOutputStream.(Unknown Source)
           at tridium.ui.admintool.DbAdminConfigPanel.doOnlineGet(DbAdminConfigPanel.java:848)
           at tridium.ui.admintool.DbAdminConfigPanel.doGet(DbAdminConfigPanel.java:764)
           at tridium.ui.admintool.DbAdminConfigPanel$Worker.run(DbAdminConfigPanel.java:1216)
TAC IA Series
  • WorkPlace Pro
  • ES
  • UNC
Either the username or password, or both, being used are invalid. A valid username and password must be entered to perform a "Save Runtime DB" of the localhost, or a "Get" to save a remote station to the localhost.
Use a valid station username and password to perform these functions on the localhost.
  • TAC IA Series
  • 17662
