"Application not found" when attempting get system or trace log
  • "Application not found" when attempting get system or trace log
  • PeterEdvik
    PeterEdvik
  • Benji
    Benji
‎2018-09-10 01:46 PM
When attempting to get the trace or system logs through WorkStation, you get the following error
  • Building Operation WorkStation
  • Detected in version 1.6.1
  • Windows 7 or below
The program or editor associated with the file type *.log can not be found on the PC.
Associate a valid program with the filetype *.log
1. Create a new text file e.g. on the desktop
2. Change the file extension on the file from .txt to .log - refer to the following instructions if the file extension is not visible
3. Double click the file, and select a new default editor
4. Get the trace log from WorkStation
Tags (2)
  • 18575
  • PeterEdvik19
