"??12293" error message when trying to log into Vista Workstation
  • "??12293" error message when trying to log into Vista Workstation
  • SESA116857
    SESA116857
‎2018-09-06 03:04 PM
Vista Workstation
If a message window appears stating "Could not connect to TAC Vista Server." in the title and "??12293" in the main window then you are trying to log into Vista using the wrong authority style.
  1. Trying to log into Vista using a Windows account when Vista is in Low authority.
  2. Trying to log into Vista using a Vista account when Vista is in High authority.
  • 2090
