preventDefault() Javascript function not working on Mouse Up
  • preventDefault() Javascript function not working on Mouse Up
  • Jonas_Brissman
    Jonas_Brissman
  • LeeCravens
    LeeCravens
  • Derrick_Ratliff
    Derrick_Ratliff
‎2018-09-06 09:43 AM
Last Updated: Administrator CraigEl Administrator ‎2025-08-29 02:15 AM
The preventDefault() JavaScript function does not work as expected when used with the Mouse Up event.
Building Operation Workstation
Users may attempt to override the default behavior of the Building Operation Properties Editor by using preventDefault() on the Mouse Up event. However, the editor is triggered by the Mouse Click event, not Mouse Up.
To successfully prevent the default behavior and override the launch of the Properties Editor:
  1. Select the TGML Script where the interaction is defined.
  2. Use the onClick event instead of onMouseUp.
  3. Add the following line inside the onClick function:
    evt.preventDefault();​
Tags (2)
  • 15536
  • JonasBrissman25
100% helpful (1/1)
