missing the first entry in ACTrans table
  • missing the first entry in ACTrans table
  • sesa139513
    sesa139513
‎2018-09-06 03:24 PM
In I/NET Seven, I’m missing the first entry in ACTrans table. I am in the process of upgrading the site from I/NET 2000. The Site is now running I/NET Seven revision 1.00 or 1.01.
I/NET Site
This is a reported bug that has been fix in I/NET Seven rev 1.02 (Track Record #3436).
DbCreate (which is a TAC product) was failing to import the first entry in the ACTrans table. Now, when an I/NET 2000 database is migrated, all entries will be brought to I/NET Seven. Subsequent edits can be performed and the list will remain intact.
  • TAC INET
  • 1213
