lc_checkout failed: Cannot checkout an uncounted license within a Windows Terminal Services guest session.
  • lc_checkout failed: Cannot checkout an uncounted license within a Windows Terminal Services guest session.
‎2018-09-07 03:55 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:30 AM
Vista 5.1 license is not working.  Trying to launch Vista components results in error:  lc_checkout failed: Cannot checkout an uncounted license within a Windows Terminal Services guest session.
Vista 5
Terminal Services
Virtual Machine
VM
There is a special feature needed in the license which allows the use of Terminal Services.
You must download the 14 day Demo TS Evaluation License on The Exchange Download Center.
*note that Terminal Services are only supported in Vista 5
  • 4282
