dwg import to Graphic Editor fails
  • dwg import to Graphic Editor fails
  • Chris_Asbury
    Chris_Asbury
  • sesa139513
    sesa139513
‎2018-09-11 10:25 AM
Importing of AutoCAD .dwg files fails to import into StruxureWare Building Operation Grahics Editor
StruxureWare Building Operation site
It is the third party library Leadtools that fails to convert the file. The files in question are constructed with version post 2010 but our Leadtools library is from 2006. To fix this issue the Leadtools library needs to be updated. This will be fixed in a future release. The dwg drawings will need to be saved in an earlier release for compatibility with Graphics Editor.
Tags (6)
  • 16798
  • adding
  • alm
  • qc25020
  • qc26418
  • sbo
