b3 or i2 PE Script program not working
  • b3 or i2 PE Script program not working
  • Dave_Shore
    Dave_Shore
  • AbeMeran
    AbeMeran
‎2018-09-11 07:57 AM
Last Updated: Dave_Shore Schneider Alumni (Retired) ‎2022-08-16 03:55 AM
PE Script program created in b3 or i2 has no error but its not executing.
  • Infinet i1, I2
  • BACnet b3
  • Automation Server, AS, ASP, ASB
Program compilation was not valid.
Examine the code and determine what is causing the compilation issue.
Known causes...
1. Variable declared in the code but not used (unbound)
Tags (2)
  • 16729
  • DavidShore22
0% helpful (0/1)
