aSENSE m III CO/CO2 sensor 0-20/4-20mA output
  • aSENSE m III CO/CO2 sensor 0-20/4-20mA output
‎2018-09-10 06:18 AM
Last Updated: Crewman ContentModerator ‎2025-08-11 04:05 AM
A CO/CO2 sensor with 0-20/4-20mA outputs is requested in our portfolio.
aSENSE m III
CO sensor
CO2 sensor
The option of having a CO/CO2 sensor with 0-20 or 4-20mA outputs is sometimes requested.
The aSENSE m III CO/CO2 sensor (part no 6553063000) is capable of both current and Voltage outputs. It's also configurable between 0% or 20% start point. These configurable options are made by positioning of jumpers on the connection board. See Senseair installation manual.
  • Field Devices
Tags (2)
  • 7223
  • ppm
0% helpful (0/1)
