Zbuilder will not launch from LonMaker on Windows Vista
  • Zbuilder will not launch from LonMaker on Windows Vista
  • SESA116857
    SESA116857
‎2018-09-06 01:27 PM
Zbuilder will not launch from LonMaker on Windows Vista.
If running LonMaker in elevated mode or with User Access Control disabled then trying to launch Zbuilder will result in an error:
Unhandled exception thrown.
Message: Object reference not set to an instance of an object.
StackTrace: at TAC.Xenta100ConfigTool.Framework.LNS.LnsNetworkManager.OpenNetworkAndSystem(String network)
at TAC.Xenta100ConfigTool.Framework.LNS.LnsNetwork.InitLNSPlugIn(String objectPath, String mode, String networkInterfaceName)
at TAC.Xenta100ConfigTool.Program.RunAsLnsPlugIn(Assembly frameworkAssembly, String[] args)
at TAC.Xenta100ConfigTool.Program.Main(String[] args)
LonMaker 3.2
Vista 5.1.0, 5.1.1, 5.1.2
Windows Vista
When the Vista Toolpack 5.1.0 was developed, LonMaker did not support Windows Vista limiting the ability to test for compatibility and all problems. As a result this problem is only experienced when launching Zbuilder from LonMaker.
Upgrade the TAC Toolpack to version 5.1.3 or higher. If Vista Server is being used as well then ensure that the Toolpack and Vista Server versions are still the same revision.
  • 5880
