ZBuilder checkbox selections by mistake
  • ZBuilder checkbox selections by mistake
  • MathiasBj
    MathiasBj
‎2018-09-06 02:47 PM
TAC Xenta 121 Plug-in, Checkbox selections by mistake.
  • Xenta 121 Plug-In
  • ZBuilder
Checkboxes in ZBuilder are sensitive for mouse click “outside” the checkbox.
When clicking on the same row as the checkbox might trigger the checkbox to be checked/unchecked by mistake. Changing the value of a checkbox might change the physical I/O configuration list, and the functionality of the TAC Xenta 121 device. This could happen by mistake if a user clicks the plug-in window to activate it or bring it to focus and might not be aware that the plug-in trigger this event as a checkbox selection.
Be aware of this and double check your configuration settings and the physical IO configuration list before exiting the TAC Xenta 121 plug-in.
  • 3050
