Xenta webserver trendlogs - Server is busy error
  • Xenta webserver trendlogs - Server is busy error
  • sesa150561
    sesa150561
‎2018-09-06 01:59 PM
  • Trendlog
  • Server is busy. Please try viewing the page again later
  • Diagram
The error looks like a java popup with error "Server is busy. Please try viewing the page again later"
Xenta webserver
It may take up to 15 minutes before a trendlogs actually starts (Depending on how many trendlogs that are available in the Xenta) after a restart of a Xenta webserver. During this time a Java error might appear if you try to call something including values from a trendlog i.e. Diagram
The server is trying to startup all the trendlogs so please wait up to 15 minutes and try to view the page again.
  • 4968
