Xenta error log - NoLink 29
  • Xenta error log - NoLink 29
  • Benji
    Benji
  • sesa150561
    sesa150561
‎2018-09-06 02:27 PM
  • Xenta Servers
  • Xenta 511, 527, 701, 711, 721, 731, 913
When checking the error log of an Xenta there is a error "NoLink 29". The error means that the network cable has been unplugged or that the Xenta has lost contact with the host in another way.
1. Check so that there is no loose ends on the TCP/IP cable connected to the Xenta and the router/switch.
2. Check with IT department to see if there has been any planned or unplanned disruption on the network.
Labels (2)
  • TAC INET
Tags (3)
  • 3940
  • No Link 29
  • Xenta Error Log
