Xenta Servers use a 10 Base T network port at 10Mbits/sec, half duplex
  • Xenta Servers use a 10 Base T network port at 10Mbits/sec, half duplex
  • LeeCravens
    LeeCravens
‎2018-09-06 12:09 PM
Some managed switches have settings that have to be configured to match the communications type and speed of the connected devices.
  • Xenta 511, 527, 527-NPR, 555, 701, 711, 721, 731, 911, 913
Some managed switches have to be configured to match the communications type and speed of the connected devices.
Most switches automatically detect the speed and configuration of the connected devices. However, for those site where these configurations must be manually configured, the specs below should be noted.
All Xenta Servers use a standard 10 Base T network port. These ports operate at 10 Mbits/sec. and are half duplex.
Labels (3)
  • Satchwell MicroNet
  • TAC INET
  • 8287
