Xenta Server as a LON Node
  • Xenta Server as a LON Node
  • Derrick_Ratliff
    Derrick_Ratliff
‎2018-09-06 12:44 PM
Xenta Server installation on a LON network
LNS Network
Installing a Xenta Server on a LON network
The Xenta Server can be installed anywhere along the LON channel as long as the terminators are located at each physical end of the wire. The server will function the same as any other LON node.
Labels (3)
  • TAC IA Series
  • TAC INET
  • 7211
