Xenta - No system messages (Offline alarms) when routing the alarms to an alarm object located on another server
  • Xenta - No system messages (Offline alarms) when routing the alarms to an alarm object located on another server
  • sesa150561
    sesa150561
‎2018-09-06 12:14 PM
  • No offline alarms
  • No system messages
  • Xenta offline
  • Link alarms to event object
  • Vista
  • Xenta
You cant directly trigger an alarm object located on another server by "Link alarms to Event object" This alarm object needs to be locally.
You will have to configure a system alarm to trigger an alarm object located locally
  • 8156
