Xenta 511/527 with Port Forwarding - Login allowed but after login page times out and page cannot be displayed
  • Xenta 511/527 with Port Forwarding - Login allowed but after login page times out and page cannot be displayed
  • Anonymous user
‎2018-09-06 03:01 PM
Last Updated: Administrator DavidFisher Administrator ‎2019-05-28 06:47 AM
Xenta 511/527 with Port Forwarding - Login allowed but after login page times out and page cannot be displayed.
TAC Vista
  • Xenta 511
  • Xenta 527
Firewall/router settings must be adjusted by the site administrator to accommodate the redirect.
Tell the router/firewall administrator that the 511/527 redirects ports from https to http so you will need the firewall/router setup to accommodate this.
If there is a delay in getting this done, the work-around is to type in the missing redirect address. For example your ports are https - :9443 and http - :9080.
  1. Login to the 511/527 https://xxx.xxx.xxx.xxx:9443/www/index/Slogin.html the 511/527 redirects you from https to http and it will not get the redirect with the "Button" and you will get http://xxx.xxx.xxx.xxx:9080/www/index/index.html
  2. After the last "/index" type in "Button" so the link looks like below http://xxx.xxx.xxx.xxx:9080/www/index/indexButton.html and type enter.
  3. You'll now be able to navigate as usual in the 511/527.
Tags (4)
  • 2485
  • After login page times out
  • Login allowed
  • Xenta 511_527 with Port Forwarding
