Xenta 100 series XIF File locations with a Vista Classic Network (no Toolpack installed)
  • Xenta 100 series XIF File locations with a Vista Classic Network (no Toolpack installed)
  • Anonymous user
‎2018-09-06 02:47 PM
If I am doing a Vista classic network and do not have the TAC toolpack installed where are my xif files for 100 series controllers?
  • Vista Classic Network
  • Xenta 100 series controllers
If LonMaker or NL220 are installed, then XIFs for TAC products are stored in the Import\TAC folder. However, on a classic network, this software wouldn't be installed, so the file path to find the 100 series XIFs changes.
If running vista 5.1.3 and prior the file directory is:
C:\Program Files\TAC\TAC Vista X.X.X\$ini
If running vista 5.1.4 and up the file directory is:
C:\Program Files\Schneider Electric\TAC Vista X.X.X\$ini
  • 3069
