XIF parser fails due to "-sign.
  • XIF parser fails due to "-sign.
  • MikaelKrantz
    MikaelKrantz
‎2018-09-06 10:21 AM
The XIF parser could fail if there is a "-sign in a commented row in the XIF default field.
TAC Vista
The XIF parser could fail if there is a "-sign in a commented row in the XIF default data field.
Example:
FILE value 1 1
##dde1  "1,2,3\x00,1,2;"         // UCPTdownDriveTime                SNVT_time_sec
0x66,0x66
##dde3 "1,2,23x00,2,2;"         // UCPTupDriveTime                     SNVT_time_sec
Just removing the "-sign will work:
FILE value 1 1
##dde1 1,2,3\x00,1,2;           // UCPTdownDriveTime             SNVT_time_sec
0x66,0x66
##dde3 1,2,23x00,2,2;         // UCPTupDriveTime                   SNVT_time_sec
Tags (2)
  • 13389
  • xif-file
