XBuilder generation output will not show all of the info, warnings, and error messages.
  • XBuilder generation output will not show all of the info, warnings, and error messages.
  • Benji
    Benji
  • SESA116857
    SESA116857
‎2018-09-06 01:32 PM
When using the Generate project command in XBuilder the Generate output screen will not show any errors even though it reports an error was encountered or the error is visible but the info message indicating what it was trying to build the caused the error is not visible.
Using the Window-> Restore Default Settings does not correct this.
TAC XBuilder
A filter has been applied to the Output window.
Right click in the Output window and ensure that each of the following options are selected:
  • Show Info Messages
  • Show Warning Messages
  • Show Error Messages
Labels (3)
  • Satchwell MicroNet
  • TAC INET
  • 5826
