XBuilder crashes when a LNS network is inserted
  • XBuilder crashes when a LNS network is inserted
  • SESA116857
    SESA116857
‎2018-09-06 02:53 PM
  • XBuilder
  • LNS Network
XBuilder will crash when a LNS network is inserted that contains a XIF file which has multiple signals with the same name.
If Vista 5.0.0 or higher is being used you can create a Vista database solely for the purpose of inserting it into XBuilder to avoid this problem.
Otherwise the XIF file will need to be modified to remove the duplicate names and the template replaced with the new XIF file.
  • 2808
