Workstation does not delete from database correctly
  • Workstation does not delete from database correctly
  • Dave_Shore
    Dave_Shore
‎2018-09-06 01:51 PM
Object does not delete from database correctly
Continuum 1.81 only seen in this version on XP
When deleting the workstation using Continuum explorer only the objects within the workstation get deleted, the workstation does not.
Run Continuum Analyzer when you see a failed item, run the "clean".
(Always backup the database before using the "clean" command)
  • 5131
