Workplace Tech Hardware Tag is Outlined in Red
  • Workplace Tech Hardware Tag is Outlined in Red
  • RandyDavis
    RandyDavis
Guinan RandyDavis Guinan
‎2022-06-30 12:18 PM
on ‎2022-06-30 12:18 PM
The WorkPlace Tech application drawing contains a hardware tag that is outlined in red and displays this error message when viewing the right-click Display Errors option for the tag
TAC IA Series, EcoStruxure Building Operation
  • I/A Series WorkPlace Tech
  • Building Operation Workstation (WorkPlace Tech Editor)
  • Microsoft Visio
The issue may be caused by incorrect copying and pasting of objects inside or between drawings.  An absolute cause has not been determined
  1. Open the application in WorkPlace Tech or Editor.  Don't open the .vsd or .vsdx file in Visio alone.
  2. Enable the Developer in the Visio ribbon. File/Options/Customize Ribbon/check "Developer"  The Developer must be enabled to have the Show ShapeSheet option available
  3.  Right-click the Input object and select Show ShapeSheet
  4. In the ShapeSheet:
    ConnectFault_5.gifStep 1. Select the corrupted string for the Connection Points
    Step 2. Delete the string
    Step 3. Click the green check mark to save
  5. Unlink and Relink the connector between the previously corrupt object, UI01 in this case, and the Analog Input object.  Note, that this could be a Binary Input object as well.  This will add the correct string to the Connection Points.
Labels (2)
  • TAC IA Series
Tags (2)
  • RandyDavis22
  • too many connections
100% helpful (1/1)
