WorkPlace Tech revision 5.7.7 installed on a Windows Server 2003, 64-bit machine: "Error initializing the dispatcher for WorkPlace Tech. WorkPlace Tech may need to be reinst...
  • WorkPlace Tech revision 5.7.7 installed on a Windows Server 2003, 64-bit machine: "Error initializing the dispatcher for Work...
‎2018-09-10 12:03 AM
Last Updated: Crewman ContentModerator ‎2025-08-11 04:07 AM
WorkPlace Tech revision 5.7.7 installed on a Windows Server 2003, 64-bit machine, receives the following error:
WorkPlace Tech Tool version 5.7.7
Windows 2003 Server, 32 bit or 64-bit
Windows 2008 Server, 32 bit or 64 bit (multiple processors)
WorkPlace Tech Tool (WPT) is not supported on computers with Windows Server operating systems, nor on computers with 64-bit operating systems.
Install on an approved hardware platform, per the Installation Instructions.
  • TAC IA Series
  • 5578
0% helpful (0/1)
