WorkPlace Tech Flow Balance tool fails with error "Unable to read previous balance values"
  • WorkPlace Tech Flow Balance tool fails with error "Unable to read previous balance values"
  • sesa119747
    sesa119747
  • Kim_Baze
    Kim_Baze
‎2018-09-06 02:34 PM
Last Updated: Administrator DavidFisher Administrator ‎2019-08-06 02:21 PM
When balancing a MNB VAV box with WorkPlace Tech Flow Balance tool it fails when starting the "Maximum flow" function with an error that states "Unable to read previous balance values."
TAC IA Series
  • MNB VAV
  • WorkPlace Tech
This error indicates there is invalid data in the memory location where the balance data is stored.
To clear the error:
  1. Open the WorkPlace Commissioning tool
  2. Select the VAV box in question and launch the flow balance software from the WorkPlace Commissioning tool. Balance page opens.
  3. Click on "Balance Data" in the left column.
  4. On the "Flow Balance Details" window, click on the "clear" button
  5. Click OK.
  6. Start the Flow Balance process again.
  • TAC IA Series
  • 3628
