Wiring an STR-202 slide stat and override into a Xenta 102-AX
  • Wiring an STR-202 slide stat and override into a Xenta 102-AX
  • Sacco
    Sacco
‎2018-09-07 01:13 AM
Last Updated: Administrator DavidFisher Administrator ‎2020-10-24 02:27 PM
TAC Vista
  • STR-202
  • Xenta 102-AX
The STR-202 wiring guide does not explicitly describe jumping together pins 14 and 15 of the STR and landing them both on U4 of the 102-AX.
  1. Pins 14 and 15 of the STR-202 must be jumpered together.
  2. This output is then connected to input U4 of the 102-AX.
  3. Be sure to set the hardware configuration to "Slide Stat" in the hardware configuration tab of the 102-AX plug-in.
  • 2348
This is a heading
