Wireless Sensor Interface on Xenta Server
Select a Country
  • Wireless Sensor Interface on Xenta Server
  • SESA116857
    SESA116857
  • Sacco
    Sacco
‎2018-09-06 01:29 PM
Can Inovonics wireless equipment be used with Xenta Servers?
  • Xenta Servers
  • Xenta 511, 527, 555, 701, 711, 721, 731, 913
The Inovonics Frequency Agile product line which is compatible with the Xenta Server driver is being obsoleted by the manufacturer Inovonics at the end of 2011.
If you have existing devices installed in the field then they should continue to work and function.
New installations should explore other options for wireless sensors due to unavailability from the manufacturer.
The ability to add a RS232 wireless Inovonics interface was removed from XBuilder beginning in version 5.1.8.
Labels (3)
  • Satchwell MicroNet
  • TAC INET
Tags (4)
  • 5803
  • Inovonics
  • wireless
  • xenta server
