Windows Server 2008 R2 compatibility with Continuum
  • Windows Server 2008 R2 compatibility with Continuum
  • sesa116871
    sesa116871
‎2018-09-06 01:32 PM
Can Continuum run on a Windows Server 2008 R2 system?
Continuum Cyberstation and webClient
Installing Continuum software on a Windows Server 2008 R2 operating system.
Windows Server 2008 and Windows Server 2008 R2 is supported in Continuum version 1.91 and later.  It is supported in 32-bit and 64-bit environments only when used for a LAN system database server (neither Cyberstation nor webClient can be installed on the PC).  In addition, only the use of MS SQL 2008 is supported.
  • 5714
