Will the TRENDLOG ID change when upgrade the vista Database.
  • Will the TRENDLOG ID change when upgrade the vista Database.
  • Sampath_Konda
    Sampath_Konda
‎2018-09-06 12:52 PM
Will upgrading a site make any changes to the TRENDLOG ID (not GUID) in the SQL database (DB).
Vista 5.1.X
Vista 5.1.7
Some third party software packages (such as energy monitoring packages) that rely on the "TRENDLOG ID" as a reference to obtain data from the Vista trend log database, will not work properly if the "TRENDLOG ID" changes.
No, the "TRENDLOG ID" will not change when log database is upgraded from 5.1.X to 5.1.7.
  • 6978
