Will Signal XP software run on Windows 7 in the XP mode?
  • Will Signal XP software run on Windows 7 in the XP mode?
  • sesa116873_brid
    sesa116873_brid
‎2018-09-06 01:31 PM
Signal XP, Windows 7
SIGNAL XP software has not been tested or validated to be compatible with the Microsoft Windows 7 operating system or running in either Windows 7 XP or Virtual XP mode.
Since the product is obsolete, no further engineering work will be done with the product.
  • TAC IA Series
  • 5722
