Will CSI/TAC formatted mag-stripe encoded cards be encoded during the Badge printing process using a datacard printer?
  • Will CSI/TAC formatted mag-stripe encoded cards be encoded during the Badge printing process using a datacard printer?
‎2018-09-06 03:30 PM
IDWorks Datacard printer
Event Handler ensures that the correct issue level is encoded on the card. Note: there are two version of the Event Handler.
Yes you can, provided you add a plug-in called the "Event Handler" written by Datacard.
  • TAC INET
Tags (3)
  • 925
  • Datacard
  • ID Works
