Why do some MNB-300 / MNB-1000-15 bases have blue I/O connectors and others have green or black I/O connectors?
  • Why do some MNB-300 / MNB-1000-15 bases have blue I/O connectors and others have green or black I/O connectors?
  • sesa116868
    sesa116868
‎2018-09-06 12:21 PM
Customer has received some MNB-300 bases that have green connectors instead of the usual blue ones.  Are they interchangeable?
I/A Series MNB-1000, MNB-1000-15, MNB-70, MNB-300 and associated base part numbers MNB-BASE-15, MNB-BASE-1000 or MNB-BASE-300
Manufacturing parts procurement variations.
Bases are  fully interchangeable with other bases of the same part number, regardless of the color of the I/O colors.
This color variation does not apply to the power or communications connectors.
Power is always a three-pin Green connector.
BACnet-MS/TP is always a three-pin orange connector.
MNB-1000-15 communications trunk and corresponding connector on the MNB-1000 is  three-pin Black connector.
  • TAC IA Series
  • 7935
