Which valve to use with the MZ140 actuator?
  • Which valve to use with the MZ140 actuator?
  • SESA150559
    SESA150559
‎2018-09-06 09:46 AM
When replacing a valve where the MZ140 actuator is used, which valve will fit?
MZ140-24T
MZ140-230T
VZ208E, VZ308E, VZ408E
VZ208C, VZ308C, VZ408C
Valve that fits the MZ140 actuator
The MZ140 is designed to be used with the VZ*08* valves (VZ208E, VZ308E, VZ408E
VZ208C, VZ308C, VZ408C).
  • Field Devices
  • 15312
