Which controllers support the String object?
  • Which controllers support the String object?
  • Dave_Shore
    Dave_Shore
  • Chris_Asbury
    Chris_Asbury
  • PaulFr
    PaulFr
  • DavidChild
    DavidChild
‎2020-10-05 07:32 AM
on ‎2020-10-05 07:32 AM
Can Strings be used in all controller types?
Andover Continuum, EcoStruxure Building Operation
  • All Continuum Controllers
  • b3, i2 Controller (EcoStruxure Building Operation)
Some Controllers do not support strings
The String class of object are supported in the following products:
CX series (including all Netcontrollers), bCX series, CMX series, ACX series, i2 series (except i2885, i2887), BACnet series (except b3885, b3887), DCX 250, CyberStation.
Labels (2)
Tags (2)
  • 15818
  • DavidShore20
100% helpful (1/1)
