Which SNMP download file is required?
  • Which SNMP download file is required?
‎2018-09-11 05:41 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:28 AM
On the extranet site, there are two .zip files (SNMP+V1.0+MIBs.zip and SNMP+v2C+MIBs.zip). What is the difference?
SNMP Alarming
Not sure which file to use.
On The Exchange Download Center, there are two .zip files (SNMP MIBs v1.0 and SNMP MIBs v2C).
The choice between the above files will likely be dictated by the site IT Department, based on their Network Management System. The V1.0 and V2C is the version of the SNMP protocol and is independent of the Continuum controller model and version.
Here's some background information on the protocol versions: http://en.wikipedia.org/wiki/Simple_Network_Management_Protocol#SNMPv1_.26_SNMPv2c_interoperability
  • 13617
