Which NEMA 4 classed DuraDrive actuators can be used with the VB-7323 diverting valves
  • Which NEMA 4 classed DuraDrive actuators can be used with the VB-7323 diverting valves
‎2018-09-06 02:30 PM
on ‎2018-09-06 02:30 PM
NEMA 4 classed DuraDrive actuators cannot be used with the VB-7323 diverting valves
  • NEMA 4 DuraDrive actuators
  • VB-7323 diverting valves
There are no NEMA 4 solutions available. Consider using the MA-318 or 481 for two position applications. No modulating spring return options are available but non-spring return gear train actuators with AV-391 (150 pound plungers) can be used when the AM-363 gasket is added.
  • Field Devices
  • 3816
