Where to find the OS version in SP-C Firmware 2.0.8 Build 921 and higher
  • Where to find the OS version in SP-C Firmware 2.0.8 Build 921 and higher
  • RobertAndriolo
    RobertAndriolo
Picard RobertAndriolo Picard
‎2021-01-21 10:00 PM
on ‎2021-01-21 10:00 PM
After upgrading SP-C to firmware 2.0.8.921, could not locate the OS version anymore
Security Expert
SP-C Firmware 2.0.8.921 and above
The web interface has significantly changed in these later builds; as such, it was not intuitive where this information had been moved too.
To see the OS version of the SP-C.
  1. Navigate to the Application Software page
  2. Under Controller Software heading Click on Current Version
  3. Four additional items will now appear below the displayed current version. One is the OS version.
  • EcoStruxure Security Expert
Tags (2)
  • ChrisAsbury22
  • RobertAndriolo21
