Where can standard graphics and snippets be found?
  • Where can standard graphics and snippets be found?
‎2018-09-11 02:51 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:28 AM
Example graphics components required
TGML - Building Operation Graphics Editor
No standard graphics or components are supplied within the product.
A Standard graphic component library can be downloaded from the Buildings Download Center.
This consists of a number of Component Libraries that can be installed on a Workstation by double clicking on each one.
In your TGML Editor, Right click in the Components window and select "Categories" you can then select the categories you require to see in your components section.
There are also a lot of standard Snippets that have been developed by users around the world, these are available to download from the EcoStruxure Building Operation Forum - Graphics Exchange.
  • 15498
84% helpful (5/6)
