When will the connection in a Dial network disconnect?
  • When will the connection in a Dial network disconnect?
‎2018-09-06 03:25 PM
Xenta 901
The 901 connection will continue as long as live values are being viewed.
If the Status window is open (for example), the connection will continue until that window (and any other window viewing live data) is closed.
  • 1128
