When using Workplace Tech, links won't create between two objects. No matter what type of objects, the link line remains red and the application will not link the two objects.
  • When using Workplace Tech, links won't create between two objects. No matter what type of objects, the link line remains red ...
  • sesa119747
    sesa119747
  • sesa116871
    sesa116871
‎2018-09-06 02:56 PM
Workplace Tech
In Microsoft Visio, the Snap & Glue feature is disabled.
 To enable Snap and Glue go to Tools > Snap & Glue, then check the Snap box and the Glue box.
  • TAC IA Series
  • 2676
