When using WorkPlace Tech on a Windows Vista computer, the LON USB adaptor will not configure properly to work with my site.
  • When using WorkPlace Tech on a Windows Vista computer, the LON USB adaptor will not configure properly to work with my site.
  • sesa119747
    sesa119747
  • sesa116877
    sesa116877
‎2018-09-06 02:28 PM
  • WorkPlace Tech installed on a Windows Vista computer
  • LON USB adaptor
The LON USB adaptor has a communication issue with both Vista and Windows 7. When configuring the LON communications via the automatic option in WorkPlace Tech, this error appears: "Error occurred in SetInterfaceDomain for domain index 0.” After this error, the LON interfaces will no longer function.
A temporary work-around is to identify the domain and use the manual configuration option.  Echelon NodeUtil, Niagara R2 WorkPlace Pro, or Niagara G3 WorkBench can be used to identify the domain, if needed.  If the domain is "0", the "Default Setup" option can be used.
  • TAC IA Series
  • 3908
