When using PSI 4.1 in direct connect mode, the baud rate is modified and saved but it will not communicate at the new rate.
  • When using PSI 4.1 in direct connect mode, the baud rate is modified and saved but it will not communicate at the new rate.
  • sesa119747
    sesa119747
  • Kim_Baze
    Kim_Baze
‎2018-09-06 02:29 PM
PSI 4.1
A baud rate change in PSI direct connect mode does not take affect until the PSI program is closed and restarted.
Closed the PSI program and restart the program for the new baud rate to take effect.
  • TAC IA Series
  • 3859
