When upgrading I/NET 2000 to I/NET Seven, if during the install process you answered Yes and specified the I/NET 2000 root directory, I/NET Seven defaults all of its default dir...
  • When upgrading I/NET 2000 to I/NET Seven, if during the install process you answered Yes and specified the I/NET 2000 root di...
  • sesa139513
    sesa139513
‎2018-09-06 03:03 PM
When upgrading I/NET 2000 to I/NET Seven, if during the install process you answered Yes and specified the I/NET 2000 root directory, I/NET Seven defaults all of its default directories to I/NET 2000.
I/NET Site
Issue when upgrading I/NET 2000 to I/NET Seven, if during the install process you answered Yes and specified the I/NET 2000 root directory, I/NET Seven will make all the default directories to I/NET 2000
Either copy the new BIN files into the old I/NET 2000 data directory, or change the I/NET configuration after the upgrade to point to the I/NET Seven data directory. By leaving everything the way it is, it will result in problems with I/NET Seven security, and transactions not showing up correctly.
  • TAC INET
  • 2097
