When tunnel through a UNC using an HTTP port other than 80 the Ax Serial Tunnel will not connect and locks up.
  • When tunnel through a UNC using an HTTP port other than 80 the Ax Serial Tunnel will not connect and locks up.
  • Kim_Baze
    Kim_Baze
‎2018-09-06 12:18 PM
R2, G3 I/A Series tunneling
Including the port number after the IP address when entering the Host address in the Ax serial tunnel window will cause it to lock up trying to connect with the port entered.
Do not include the port number after the IP address when entering the Host address in the Ax serial tunnel window.
  • TAC IA Series
  • 8010
