When trying to select meters in Building Operation QT Administrator a 'User is not authorised to access' message appears and a log list cannot be retrieved.
  • When trying to select meters in Building Operation QT Administrator a 'User is not authorised to access' message appears and ...
  • sesa177673
    sesa177673
‎2018-09-11 01:13 PM
StruxureWare Building Operation
This is most likely caused by an incorrect trend log configuration.  Either:
- One or more extended trend logs are not configured with a trend log.
or
- One or more trend logs are not monitoring a point.
Correct the configuration and retry.
  • 17404
